Hi everyone,
I recently pulled up the floor matting and on the passenger side, the juke padding was soaking wet. It is not anti-freeze, so I am wondering where I should look for this leak. I also don't believe it is coming from the passenger side door either. I was told water leakage is a common problem on these trucks!If you have some experience with this problem, I would love to hear from you!
Thanks Dale
