If you go with a Carter pump the wiring is simple. No relay is needed just a fused 12 volt power line (hot when key is on) and a ground. Also, if you add a hidden toggle switch in the power line it makes for a good anti theft device.
By the way, electric pumps aren't that new... the '63 Austin Healey 3000 I drove in college had one.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
