It's been a long time since I pulled mine, but as I recall......
Pull the 2 screws that hold the arm to the windshield frame.
Remove the handle,(fold out the crank and remove the center screw under it to remove the crank).
There should be 2 screws under the chrome bezel. When those are removed the whole assembly should drop out.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
