I always disconnect the battery on electical work. My concerns are how far do you have to tear the column down or remove stuff before you get to the switch? I know there is a pin to press to get the lockset out. But do I have to drop the column down to be able to get the switch and wiring harness out and the new setup in? None of the books I have cover any of this.
old340dog
