What diameter do you want to run ? 15" ,17", 18" ?
7's up front and 8's out back with 235/60 and 275/60 in 15" for example is a "go-to" choice
There are tons of sizes out in 18" now so you can get what you want.. 275/40, 275/45 or 285/40 for the rear for example..also taller profiles if you want as well. A 225/45 up front or 235..
