A very simple jig could be built to test how much twist the stock K-member has vs. the aftermarket ones. Fix one side of the K-member, apply a lever arm to the other side to input a torque, and measure the deflection using dial indicators.
Exactly what I was thinking... Bolt down 3 of the 4 bolts, jack it on the 4th free one with a scale pad under it...
