You must brace the Pro Street bar.
The idea of a door bar is to protect from side impact.
A pro street bar will push in during side impact which does not protect the driver. If you brace the bar from the bend at the drivers thigh back to the bottom of the main hoop you are improving the issue.
I ran my own version of a pro street door bar on my first cage. It only had one bend in it. I was required to install the brace just mentioned to make it legal.
Leon
Would the pro-street door bar brace be something like this?
