sounds like float issue. possibly float is stuck (needle/seat), or float level is too high. I would check float levels first. other possibility is if idle speed is too high(big cam, rough idle,etc.) carb may be pulling fuel in from main circuit instead of idle circuit. try reducing idle speed.
