Originally Posted By 70Cuda383
Try to bleed the clutch to ensure you didn't pull in air from anywhere. The other gears aren't a problem when shifting, since you don't need a clutch to shift once the RPMs drop and engine speed matches the next hear--it'll fall into gear without using a clutch
iagree Sounds like your not totally disengaging the clutch.
