These are basic instructions, not specific to this model.
Pull the kick panels, there is a bolt on each side.
Remove the steering column.
Disconnect the firewall bulkhead on both sides, and the wiring harness underneath that goes back.
Disconnect the heater control cables from the box.
Disconnect the defroster hoses.
Disconnect the antenna from the radio.
Remove the windshield.
Put a few blankets over the console and/or seats.
Loosen but don't remove the side bolts.
Remove the bolts at the top of the instrument panel.
With a helper, tilt down the panel, lift off of the side bolts and remove panel. Make sure nothing else is connected while doing this.
