Originally Posted By ou812
Originally Posted By moparmafia
This is my first small block build and I am looking to buy a new set of pistons and h beam rods for a 340 with a 3.79 crank. where would be the best place to purchase these.I want something that will hold up with a small shot of spray.
I use Diamond and now CP...if they have a shelf piston you like they can make a CD change for the 3.79 crank.
I also use 6.200 rods most times.
Brian
I built 3 3.79 engines.. 1 was a 9.2 block.. that one
I used Eagle 6.125 chevy H-beams with CP pistons.. the
2nd was a 9.56 block with chevy longer H-beam rods and
CP pistons.. the last was much like the 2nd but with
Diamond pistons
wave
