Try resetting the Idle strategy To do this; get the engine up to operating temp, disconnect the battery then hold the positive and negative cables together(cables not attached to the battery)for 1 min (do not use any device that prevents memory loss of the radio), Then reconnect the battery, start the engine and place in drive with your foot on the brake, let idle for one min in gear foot on the brake,
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
