I had clearance issues with the 440 source pickup so make sure it clears your rotating assembly before you bolt the pan on DAMHIK
I ended up going with the stock type pick-up with the Milodon HEMI replacement pan.
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
