The spring steel tab broke on my 68 GTX clutch fork. No problem pulling it right out. But looks impossible to install without pulling the trans and bell housing. Has anyone successfully installed a new clutch fork on a B-body (68 GTX) without pulling the trans? If so how did you do it? When you slide the new clutch fork up to the holder the TOB is too forward to install the fork? Thanks Larry J
