Robert, never paid attention to the alignment before. Drove fine. Ha I g to trim the sleeve concerned me that something was fundamentally wrong. The odd thing after this last alignment, when I gave it gas the car wants to pull to the left, but only when you give it gas. I have put new tires on since then, not sure if that was causing issues, they were from the early 90's.
Sxrxrnr, I will check the steering box and shaft position. Both have been in and out.
The car is currently on jack stands with everything hanging down. That shouldn't contribute to the issues I'm seeing correct?
