Quote: The crane units are fine on small cams up to .620..I have not used the comps...I would buy Harland Sharp rockers if it was mee.. They will work on bigger cams if you ever decide to upgrade.. poppaj
OK, I'm curious why the Crane's are limited to .620 lift?
