What is the web address or phone number of big-block-Dave so I can order one of his A body 440 exhaust spacers? Sounds like his is the best from everyone's posts. Thanks G.G.
You do understand that you only need this if you have the correct drivers side 440 manifold and want to use the original exhaust system. If you are having an exhaust system made locally you do not need really need it it.
