Sounds like something you could get from mcmastercar (www.mcmaster.com) It is just a sleeve with a hole in it.
A brass or a steel one would work (if you use steel buy a nylon washer to go between the bushing and the dist. Hell you could make a drill stop work if you had some time...
Also a machinist should be able to make one w/o any trouble it is just some round stock w/ a hole in the center w/a hole for the roll pin.
