Sorry to see, glad no one was hurt. Need much shorter rigging next time and be glad it wasn't a big block motor. I'm surprised it needed to be so far extended, the ram because the rampage it seems pretty low to the ground?
Wish I was closer you, do you have another engine crane to get the motor off your car?
Yeah I got the engine off.... the arm needs to be
that far extended... it has to go right to the
fire wall... that was about the 20th time I pulled
the engine/trans... I even do the race car the same
way.. but that trans is about 60# lighter
