Thanks much... mine is still mounted under the master cylinder, so had not investigated the idea of rebuilding it. If they are serviceable, I can certainly pull it apart and clean it up. I am replacing the brake lines as part of this project as the old originals are pretty corroded and I am having problems with particulates in the brake fluid. Tnx for the advice...
