Originally Posted By WO23Coronet
Where should the temp sensor be installed? Right in the pan?
Hotly debated topic... but I think a bung in the pan is best and most common. Also, this location is the reference for most operating temp guidelines. The line to the cooler is the right after the torque converter... hottest point in the system. Pan temp will be lower and better reference.
