On my 2002 cummins I ran a deep pan 2 quarts extra with the sensor in the pan. On the road pulling about 9,000 pounds I was at 140 to 150. Without the load 110 to 120. 200 degrees is on the very high side of what I would like to see. If your sensor is on the output line it will read a lot warmer.
