Originally Posted By BradH
Originally Posted By moparlifer
On victor heads with offset rockers, mine hit the pan rail and had to be ground for clearance and I lost a lot of sealing area when done!
The description on the page I linked above does mention needing to clearance the rail for Victor heads, so not a surprise. I know some rockers would make that more of an issue than others.
EDIT: What about distributor clearance w/ those covers on Victor heads? work
My valve covers are procomp which are similar. I also had to clearance the flange so they would drop straight down over the studs without hitting the HS rockers. I use and re-use Felpro blue stripe cork gaskets on valve covers and oil pan with no sealer and no leaks. I use an MSD distributor without issue. twocents thumbs
Those 440Source covers do look nice with thicker flanges!
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
