Well I went to T&T tonight and did not accomplish much. The air was bad and my 60 ft. times were bad. I made 2 passes with every thing the same as usual and ran a 6.36 and 6.37 at 108 mph with the normal 6800 chip in the shifter. I stuck a 7200 chip in to see what it would do. I have never shifted that high before. It ran a 6.33 shifting at 7200. Then I put a 5800 in and for some reason it did not shift into high and ran a 6.51 at 98 mph. It was turning a lot of RPM down toward the finish line in 2nd, I kept pulling the shifter back but it did not shift. So I believe it would have ran faster than the 6.51 if it would of shifted. So I am going to have to move the throttle or back timing down to slow down if it even will slow down that much to run 7.00.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
