Thanks again all, I've not been able to get into the car this week, but I appreciate the suggestions. I'll start with the easy thing: fill the tank. May not be the issue but it's easy. Then I'll see if the fuel pump shows any visual problems. Check the fuel filter too just in case and I'll look at the float adjustment too. The weather was plenty cool when it was bogging, so I'll just keep vapor lock in mind if I run out of options. Since I'm going to install an oil pressure gauge, I'll do one for fuel pressure too. If the above solves the bogging problem, I'll still eventually go to the AVS. But I'll do it knowing what solved the bogging. Cheers, I'll be on this forum as I look forward to some track time next year. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
