Why on earth would anyone use these heads? How could a major head manufacture build a head with so many dimensions incorrect? Whoever signed off on these heads should be unemployed. Power wise I've yet to see one much better than an -1. Nothing fits. You have to ask yourself why? I've seen plenty of complaints about Indy as a company, but the castings are used by the thousands without failure. In fact I think I've seen more failures on the few Victors that are being run. Nice work on the fix. I just can't see going to all that trouble for little or no gain in performance.
Doug
The Indy heads are no different. They need the rocker shafts relocated, just like any other head with cast in stands. I've done enough to know.
