ILLINOIS
Depending on your local laws, and in any state that has adopted CA emissions regulations, you'd be in violation of the law.
In an engine replacement, ie 72 225 for a 78 225, the emissions neccesary to be legal depends on either the date of manufacture for the body or the engine, whichever is later. So a 77 225 in a 72 Dart would be required to meet 77 emissions requirements, however, you cannot run a 72 225 in a 77 vehicle, engine has to be at leas teh same year or newer than the body. The ONLY exception is catalytic converters which are solely body dependant, fire hazard in a body not originally designed for it.
If your state doesn't run CA emissions, which is most, you will have to find out what the law states.
As for "emissions exempt" that means you are exempt from testing, only. Federal law, at the minimum, requires you to keep an maintain the stock emissions equipment. I do not, however, know what the feds require when doing an engine replacement, at the minimum I would guess whatever the emissions you original setup had.
As for an engine swap, ie a 440 in place of a 225, then it has to meet the requirements for the year of the body it's being swapped into or the year of the engine, it also has to be a pass car engine, if it's swapped into a pass car, and it has to be an available option in a pass car for that year. So no, 426's in a 73 Newport.
You can swap a 360 in place of a 318 as it's considered a replacement, not a swap. But it still has to meet the year criteria and have the appropriate emissions retained.
As for removing emmisions equipment to make it run better, wrong. Most have no net effect on power, some have a benefit if you use it. Granted, back in the day cats were restrictive, but they no longer are. Egr keeps ping under control allowing more dynamic compression for more power.
as for the argument of why "guys" don't run EGR if it makes more power, heck look at this thread and you'll see the answer, lack of knowlege about what it does and how to take advantage of it.
So then, how do people get away with big block swaps into post-'79 trucks? You can't tell me that nobody in Cali has ever done one of these type swaps! Also, I remember hearing the blather about that engine had to be an option in that body style, that year; though that may be what the rule book says. Another thing; Ever look in an engine catalog (ie; Jasper, etc) they often group several years' of a given engine application; how can the "same year or newer" thing fly, if, for example, they group a 77-79 318 together, your car's a 79 and your reman was an engine originally built in '77? Further; "pass car" block vs "truck" block (depending which you are swapping into) You mean to tell me, that a 318 long block of a given year is really any different for a car, vs a truck of that given year? (OK; maybe the truck has exhaust valve rotators; big deal) but casting number wise, I have a 78 Fury and an 83 D 250; both 318s both have the same casting # on the heads; neither has ever been apart since Mopar built them. Internal parts; the same set of pistons is catalogged to fit more years than would a short/long block, as I described above; how would the SAME piston act any different, in a '78 block than it would in an 89 block? the piston don't car what year block it's in! Yet the catalog shows that range for that application.
