I poured some evaporust in the gap between the spacer and the can (figure 96) - maybe that will do the trick. Expanding the can isn't really doable and heat will probably damage the diaphragm.
Originally Posted By billyfury
If you can figure out where to buy new diaphragms please let us know. I had no luck with that.
billyfury
The first one I took out looked fine - I hope that the second one is in good shape as well.
