Vin pad - Passenger side, down low.
Serial number with CID & other build info - Front face below drivers side head.
It would also have the casting number with 340 on the drivers side under the exhaust manifold.
The 4-speed transmission should be an 833 if it is the original. VIN on the passenger side of the box.
