What really triggered the question was that when brake bleeding is discussed, you are always told to start with wheel most distant from from MC, which is usually RR and the LR and so forth. It would appear with dual reservoir systems that you can safely ignore this.
Correct, this got burned into peoples' brains back in the years' when all 4 corners were connected (pre 67). Just be sure to bleed the MC first
