I did the above & was pleasantly surprised when I ended up with a significant amount of clearance which was what I was worried about (that I would not have enough) & I'd burn it up. Thank you! I still think something ain't right to where it had to be tightened too far in using the torque wrench however, double R I will check out the wrench & go from there.
