Quote: I can't say exactly how much, but can assure you it will be worth power. The farther you can keep the crank away from the oil, and the more you can get off the crank the more power you'll make. Ideally like a dry sump there would be no oil in the pan, just a big decompression area in as much vacuum as could be produced.
Darren have you seen similar gains with a dry sump and scraper?
