on my 02 it's just a 10mm nut and give them a light twist while pulling them up off the stud. If I remember correctly I did unplug the wiring before messing with them. I would also give the hole a light blast with air in case there is some sand down in the hole. I also put a dab of anti seize on the threads of the new plugs as well.
