85 cars got roller cam #302 heads carb then TBI
trucks got roller cam TBI 318 in 86-87
truck 360 tbi went roller cam in 89 with #308 heads
85-86 trucks got roller blocks with flat tappet cams 2v & 4V carbs.
all the roller gear swaps over to a roller block to convert a pre-mag LA engine.
early stock roller lifters used a solid PR with non oil thru roller lifters, 90-91 they went to hollow PR and oil thru roller lifters--getting ready for the magnum engine in 92
