Is the specified range representing factory specs or your custom specs?
Toe (toe in I hope!) looks on the low side of spec. Some toe in helps stability. I remember toe in in inches... 1/8" to 3/16" toe in at the tires being in the ball park.
Positive caster helps stability. Factory specs were near zero. If you have 2-3 degrees positive caster, "should" be OK.
Camber I don not understand. You want some negative camber in a handling application to help the tires "bite". Yours shows positive. Between -.5 degree and -.75 degree is in the ballpark.
Suggest you clarify the measurements with your shop and re-do or find a new shop.
