The difference in left and right SAI (Steering axis inclination) looks pretty high.
Are all the bushings still good?
Has the car been in an accident at one time?
Are you sure you have 2 exact same front wheels on the car?
Bushings are all good. They are all PST Polygraphite bushings and Energy Suspension k-frame mount bushings. I don't think this is the issue as I didn't have the problem before the most recent alignment.
I don't know if the car has ever been in an accident but I don't think so. I have owned it for 11 years so not since then.
Yes, both wheels are the same.
What would cause a wierd SAI?
I did have to pull the caliper/rotor/hub on the driver side to replace the lower BJ dust boot. However, if this was a stuck caliper, I would think the wheel would turn left when you let it go. This is where the wheel will pull straight but the car will go left unless you turn the wheel and hold it right.
