Originally Posted By Mebsuta
The Summit 6400 is the 214/224 @ .050, .444/.466 hydraulic.
Has anyone used it in a 383? Was it a good low-mid street cam, and what did you have for manifold vacuum at idle? Thanks.
Is this for the car in your sig, a 4 speed ? If so get the 6401 , I ran that in my 69 bee , 130k mile 383-2bbl long block with a DP4B , 3.23 gear , 4speed , power brakes , did 97mph in 1/4 at 3900 lbs , not earth shattering but the car was fun to drive.
