Roadhazard, I'll try to do that. The Lakewood bellhousing and block plate make it pretty much impossible to see anything in that area. Oil is seeping from between the block and block plate. If it turns out to be the seal, which of your kits do you recommend? I see that Mancini has two different ones.
