I think it would be a World block. P/N was P5153862AB. Was manufactured just over a year ago. Is that the right period for World blocks?
The retainer was installed in the block, as received.
The crank was hard to turn after adding the seal, but I assumed that was standard for a rope seal.
As for the retainer, should I remove it and compare the geometry to a stock version?
