Gotcha, so do you think this carb came stock without them? Obviously there is no way I will get the original Carter diagram of the 4327s..
If anyone has a junk 1967 Carter 4326 or 4327 AFB sitting around that they would split and check for me, I will find a monk that will grant you total consciousness on your deathbed...
