The blower motor can make the power at a lower engine speed which is the key here. To make the 700hp N/A will usually take more RPM. Stress/load goes up much faster with increased RPM than it does with increased HP. So the stress/load may be the same at the same HP and RPM between the 2, but additional RPM adds additional stress and load.
