I used B Body Dodge front spring hangers flipped upside down on Dad's 69 Dart. Moved the rear both back and up at the same time. On my 70 Satellite I used the Mancini B body hangers in the top hole and still had to add 1 1/2" lowering blocks to get it to sit right. The more tire your trying to use the worse it is...
