that is surprising that they are that high but maybe mine were used/had settled (I bought it as a roller) and I ain't sure which of the 002/003's is the higher but mine had (2) 003's for a level ride but I did need a pair of those garden variety shock mt extensions that I happened to have laying around. Would some lowering blocks take care of you? I would want the rear shackles at a reasonably correct angle (lower end down & to the rear ~45 deg. EDIT 14's in top pic/15's below
