The factory big block A-Body's had a 22" 3-core radiator with the drivers side lower hose and worked just fine. No reason to use a 26" radiator, cutting the core support will just make it ugly when you can just use the right parts to begin with.
JB Rhinehart, Realist
A-Body's RULE!
