Dead short in the starter?
yes but likely the hold in winding in the solenoid tho not sure how it is getting fed from the full time hot large main cable down to the large starter nut without the solenoid being pulled in. Fastest would be to R&R the starter or take his time & open it up & see whats shorted/if he can fix it. EDIT the draw is in the large cable down to the starter correct? Never seen that so I gotta double check
