Sure.. just check the balance on it
EDIT
What you have now is externally balanced with the conv
and the front balancer so you need to get a internally
balanced balancer and knock the weight off the conv
but I would still have it balanced
What do I need to know and what is involved in rebalancing this rotating assembly. I have New in the box Damper from Pro Systems, as well I will be ordering a new vert for the 3.23:1 gears I plan on running.
