iirc someone mentioned that Lowes has a paint stirrer rod that is a 5/16" hex but it might not be long enough (iirc). If you have a junk intergear you can grind the teeth down on your bench grinder & the teeth are soft & grind down pretty fast. EDIT then a speed handle/screwdriver bit
