She has a 5.2 v8 throttle body injected. She runs great but does not like to idle. If I hold the gas a tad bit, she will idle. Are there any adjustments to make? I see a bolt I can twist, but there's an electrical connector behind it. Do I have to do anything special? (Special procedure?)
Also, where can I find a wiring diagram? They wired in a kill switch, but the fuel pump will still pump with key off/kill switch on.
There's more, but I don't want to get overwhelmed haha.
