the azz end kicks out to the right also,it doesn't launch perfectly str8.As you can imagine with a 512, 2800 stahl and 4:10 gears all hell breaks loose when the go pedal meets the carpet
I have one of DrDiff's dana 60's with a tru trac set up. Sounds like this would help your situation. I'm amazed how well it works and goes straight even when the tires are up in smoke. I wonder if something is worn out in your rear end?
