I'd still go with it being a tire (or tires). I've personally seen tire wear act just like a bent rim. Try swapping the wheels front to back and try it out. I'm guessing you'll see a difference.
I did that on the pass side, but not the driver, and some how it moved to the driver..... I'll swap the driver side in the morning.
I thought it might be the idler arm because the steering seemed loose, but then again I have been driving RnP cars daily for a while now.
